DEAL OF THE DAY: Save 37% on the Seidio VITREO Screen Guard for iPhone 5!
Capta mount gains Kickstarter funding, an all in one stand, cable management and tripod mount [video]
The Capta mount is an all in one stand, cable management and tripod mount designed for the iPhone and other smartphones. It has just received Kickstarter funding with double the pledges required and there are still seven days to go.
Designed by two freelance designers, Bojan Smiljanic and Adewale Adelusi-Adeluyi they set about originally creating a simple and elegant tripod mount. That has now expanded and the Capta can be used for many more things. The Capta is made from airplane grade aluminium and has a adhesive pad that can hold an iPhone securely. There is also a groove for cable management as well as threaded hole for a tripod attachment.
According to Smiljanic, “With the form factor and technology of smartphones always changing we designed Capta to be the hybrid accessory that could keep up with those changes. For example for iPhone users regardless of generation, Capta replaces the iPhone tripod mount, iPhone stand and iPhone cable management with one simple device. Capta has exceeded our original expectations and when paired with a suction cup or tripod mount the uses increase exponentially. We are humbled by how versatile Capta truly is.”
If you want to be an early adopter, you can still head over to the Kickstarter page and make a pledge; $20 will get you a silver version. If you are really impressed, you could pledge the maximum $265 and get two exclusive black Capta's as well as a lot of extras too.
Source: Kickstarter
chrisoldroyd
More Posts
loading...
loading...
loading...
loading...
← Previously
Siri security protocol cracked, now possible to run on any device
Next up →
How to subscribe to and set up iTunes Match
There are 7 comments. Add yours.
Guytano Law says:
I wonder if it work with other cases and accessories
Capta lover says:
Check their updates on page, they have tests with different phones and cases.
Nick says:
I'm shocked no moron has asked if this will "work on their 3GS" yet
fastlane says:
I already have the Glif. It's great and is the size of a finger. Why is this so large?
fastlane says:
sockopen says:
In the video he uses an iPhone 4 or 4S does anyone know if this will work with the 3GS?
Autobahndude says:
I asked the same question because i have a 3gs as well and then i saw this test with 13 different phone sin their updates section. http://www.kickstarter.com/projects/1689824368/capta-stick-it-lean-it-wr...
