Case-Mate Hybrid Tough Case for iPad - accessory review
This week I am looking at the Case-Mate Hybrid Tough case for iPad. This is actually a good case considering its goal; solid protection while staying reasonably thin.
The case is unique in that it has two layers. The first layer is a silicone skin that covers the iPad and all of its buttons. It also covers the lip on top of the glass screen. The other layer is a hard plastic shell that snaps on place on the bottom of the iPad, on top of the silicone. The concept here is that it provides dust free protection while giving you a little cushion for bumps. The combination of the bottom shell and silicone protect the bottom and sides of iPad.
The only exposed areas (besides the glass, of course) are the speaker and 30-pin connector on the bottom and the rotation lock switch on the right side of iPad. There is minimal but reasonable thickness added to the device between the two layers, but I feel it is acceptable based on what the case is doing to protect your investment.
The only real issue I had with this case was removing it when I needed to attach an accessory like the dock or the keyboard dock. You have to remove it very carefully as the case is meant to fit very, very securely in order t prevent any lint build up. If you never have a need to attach iPad to these types of accessories, then there is no concern.
The Case-Mate Hybrid Tough case for iPad is what it says in the name; two layers of protective goodness and tough. It's available now for $47.95 from the TiPb iPad accessory store.
- Solid protection
- Access to all ports
- Dust-proof protection of the iPad controls
- Two available colors- gray and lime green
- Can be a challenge to remove
- Does not fit in Apple Dock
- Top and bottom of case are still "loose"
There are 3 comments. Add yours.
What star rating do you give it?
That's a really good looking case. I'm not a big fan of the texture of the hard shell, but the color accent looks really good.
@Trevor thanks! It slipped! 3.5 it is!
