Griffin announces the Twenty audio amplifier for Airport Express
Griffin has announced a new AirPlay enabled audio amplifier that uses Airport Express technology. The new accessory which is called “Twenty” captures any AirPlay stream, decodes it then sends out an amplified stream to your speakers.
The Griffin Twenty is the easiest, best-sounding solution for consumers who have speakers that are not AirPlay-enabled but still want to stream high-fidelity audio wirelessly,” said Mark Rowan, President of Griffin Technology. “Not only can users stream from their iTunes library, they can easily connect with any AirPlay-enabled iOS device.”
The Twenty can stream Apple’s lossless sound from any AirPlay enabled app on the iPhone, iPad or iPod touch as well as PC’s and Macs running iTunes. The Twenty has an inbuilt power supply and mount for Airport Express and features a 2.1 channel sound system with 20 watts power output per channel. No information on when this one will be available to buy but we will let you know when we hear anymore.
Source: Griffin
chrissyboy6969
More Posts
loading...
loading...
20
loading...
loading...
← Previously
Apple seeds iOS 5.1 beta 3 to developers
Next up →
True NightVision app updated to 2.0, new modes promise much improved light amplification
There are 11 comments. Add yours.
Dl says:
I'd love to hear some prices
Olga says:
Ok, off topic, but iPhone Hacks you should do a shout out about this..All you ppl inwhisg to change font, but are hanging out for Font Swap forget it.Check out Bytafont on Cydia; it's awesome and better than Font Swap ever was!
benjimen says:
The fact that it's limited to use >only< with an Apple AirPort Express very much limits the audience for this wonder-gizmo. With luck, future models (or a firmware update to this one) will allow use on a WiFi network regardless of base station. As I use a router plugged into a DSL internet service, I'm out of luck.
Otherwise, this definitely falls into the "exactly what I've been looking for that doesn't exist yet" category ;-)
blyths says:
Lucky for me, I am part of that limited audience. This is a perfect way to re-purpose old speakers. I have an old boom-box with decent sound, that I use an AirPort Express and a tape adapter with - I'd love to put away the main unit and just use this amp directly with the speakers. Hopefully it's priced keeping in mind that speakers and an AirPort Express need to be added to it - say in the neighborhood of $50.
And don't hold your breath on a firmware upgrade, you can't add wifi radios in firmware - that's what the AirPort Express is for
anni1980 says:
hey guys i want to inform you about this website actually getting crazy! sending free iphone 4s to all new subscriber, I don't know how long it'll work, check out herewww.bestmobilephonewikipedia.com
Wardey says:
Or buy a used AV receiver from Kijiji for $100 and have 5 times the power and X times the sound.
Alysia Bradney says:
This might not be the ideal place to ask this, but I am trying to find a pest control business within the pittsburgh region and have no method to find out who's the most effective. I located this company that is actually close to me and wished to see if any one has any reviews on them. Spectrum Pest Control, 3058 West Liberty Avenue, Dormont, PA 15216 - (412) 446-2802
Maris Fiwck says:
Este en realidad fue un articulo bastante facinante. Tengo la idea de crear mi oficina de finca raiz y por esta razon trato conocer mucho sobre el asunto y tambien acerca software y economia. Su analisisfue de mucha ayuda. En este site tambien he conseguido buena articulos
Delphine Pridgen says:
Hey guys my friends and I started making falling vids, there pretty good. Come check out my channel and tell me what you think!
Casquettes Obey says:
Great artical, had no problems printing this page either.
