Griffin stops by #CESlive to give us a look at their Square compatible Merchant Case
Griffin swung by the #CESlive stage to give John and Georgia some further insight into their latest offerings. They've teamed up with Square to offer the Merchant Case which not only provides great coverage for your device but also makes using the Square card reader with it simple and easy.
The case itself is designed to help customers slide their credit card through the Square reader and when the reader is not in use there's also a recessed spot on the back of the case store it.
The best part? The case is available now for only $19.99 and it comes with the Square dongle as well. Check out the video above to see it in action and if you're looking for more #CESlive coverage be sure to check out our portal page.
Chris Parsons
Editor-at-Large at Mobile Nations, gadget junkie, energy drinker, ranter.
More Posts
5
10
29
← Previously
How to use Do Not Disturb when your iPhone is unlocked with iOS 7
Next up →
#CESlive: Braven - Better Batteries, Better Sound
Reader comments
1 Comment
