Honeywell turns up the heat with the Lyric smart thermostat
Honeywell Lyric smart thermostat
Honeywell (yes, Honeywell) has announced their own smart thermostat to compete with Google's Nest. The Lyric, which was first leaked in April, has now been officially announced and is priced at $279. It has some visual kinship with the round Nest and thermostats of old, but it has some different tricks up its sleeves.
Visually, Lyric resembles Nest in terms of its round design with a circular display in its center (though it's not terribly large). Inside, the device uses Wi-Fi to connect to a mobile app (iOS and Android versions have been announced) so that users can set their heating and cooling temperatures inside their dwelling to their desired levels.
Lyric's biggest bullet point is its use of geofencing. In basic terms, when a person leaves their home with their smartphone, the Lyric senses when they depart and adjusts the temperature inside to a level designed to save money. When that same person makes the return trip home, the Lyric again detects when the person is getting close and adjusts the temperature again to make sure that the home is comfortable again when the home owner enters.
Honeywell adds:
The Fine Tune feature factors indoor and outdoor temperature, humidity, and weather into its algorithm, enabling it to provide the most comfortable temperature for homeowners. No other do-it-yourself Wi-Fi thermostat on the market today does that.
While the Honeywell Lyric is already available to purchase by professional heating and cooling contractors, it will be sold to the general public, via Lowe's, sometime in August.
Source: Honeywell
John Callaham
News Writer for Mobile Nations, along with being a Space: 1999 fan
More Posts
5
21
33
← Previously
New and updated apps: PhotoCard, Twitter, Republique
Next up →
Does the 7:1 split tempt you to buy more AAPL stock?
Reader comments
7 Comments
Honeywell has been making round thermostats for at least 50 years. If anything round Honeywell thermostats were the inspiration behind the design of Nest.
So it seems it might be using a different app than the other thermostats Honeywell uses currently. It definitely research once it's out to see if it's worth changing to this one over my basic one that works well for me right now.
Darn! I just got the Lennox smart thermostat (to go along with the new furnace/AC). It works well but is huge (7" touchscreen). Every installer I talked to did not like the Nest with new multi-stage furnaces/blowers.
Talking my my furnace guy, he says most don't like it, but it's mainly because it's a consumer facing, self install .. which means HVAC companies don't make much, if anything, from a Nest unit. Basically, Nest saw fit to go around HVAC industry, and they didn't like that..
I'd buy it, the geofencing is pretty cool and would automatically start saving you money without any interaction. Plus, another device to give you the forecast / current weather too :)
