How to quickly search Yelp with the help of Launch Center Pro
Want a faster way to find coffee shops, italian restaurants, or whatever food and drink you love best? Then Launch Center Pro and Yelp are for you. Combine Yelp's knowledge base with Launch Center Pro's fast actions and it's a match made in traveler and road-worrior heaven!
How to search Yelp reviews on iPhone and iPad with Launch Center Pro
  1. Open Launch Center Pro on your iPhone or iPad.
  2. Tap on the Edit button in the upper right hand corner.
  3. Tap on a blank square either on the main screen or inside of an existing group.
  4. Select Action Composer.
  5. Now choose Featured apps.
  6. Scroll towards the bottom and tap on Yelp.
  7. Tap on Search
  8. Change the Name of the action if you'd like.
  9. Optionally you can pre-populate common search terms or you can leave it blank to just launch the search page. Once you're finished, tap Done in the upper right hand corner.
  10. Tap Done two more times in order to finish saving the action.
If you want to search for all the places around you, leave the search field blank.
If you want to filter locations, to focus on coffee shops, certain types of restaurants, or anything more specific, add terms to the search field.
Give it a try and let us know how it works for you! Have you set up actions like this with other apps using Launch Center Pro? Let me know in the comments!
Allyson Kazmucha
Senior editor for iMore. I can take apart an iPhone in less than 6 minutes. I also like coffee and Harry Potter more than anyone really should.
More Posts
loading...
loading...
35
loading...
loading...
← Previously
ETA for iPhone gives you drive times at a glance
Next up →
Start your week off with the best Apple podcasts in the 'verse!
Reader comments
5 Comments
These tutorials are really well done, but it seems that most center around LCP (at least seven articles in the last month or so...) I know I sound a bit curmudgeonly, but it would be great to get similar coverage of other apps - though I'm sure LPC enjoys the promotion. Perhaps you get a lot of requests for help with it...
We do. It's one of those apps that are amazingly useful but people seem to have a hard time deciding how to set it up or how. But we have more third party app how to's coming. If you have any suggestions or requests on ones you'd like to see, feel free to drop me a line at ally@imore.com :)
This a some great tips and step by step how to. Now, I just need for launch center pro to reduce their price on those apps. Too expensive!
Sent from the iMore App
Believe me, the amount of time you save on a regular basis makes it more than worth the price tag. Plus the developer is responsive and consistently updating and making it better.
