Incipio Premium KICKSTAND Case with Stylus for iPad review
The Incipio Premium KICKSTAND Case with Stylus for the iPad packs a lot of features into one solid package. Not only is it a folio with a secure flap, but as the name implies it comes packing a kickstand for excellent -- and multiple -- viewing angles, and even a stylus pen for note-taking, drawing, and gaming.
Thanks to its durable, rip-stop nylon exterior, the Incipio Premium KICKSTAND Case with Stylus can more than hold up to the every day wear and tear that occurs when taking your iPad out and about. The soft micro-suede interior keeps your iPad safe and cozy inside as well. Slide it in and it stays in until you slide it out.
You have good access to all the ports and controls, at least as good as any folio-style case can provide. But the big story here is the kickstand. Since the iPad doesn't have a built-in kickstand like the Microsoft Surface, accessories have to pick up the slack. And I'm not going to lie -- I like them a lot. The kickstand on the Incipio Premium is really flexible, allowing you to position it for typing and for video watching with ease.
Thanks to the mini front flap, you can even adjust the video viewing angle to one of three options.
As to the stylus, it's sort of a bonus. If you're serious about your stylus pen, you'll probably have picked one specifically for your needs. If you haven't got one already, the Incipio is fine for every day use.
The good
- Solid build
- Flexible kickstand options
- Includes stylus and stylus storage
The bad
- Folio cases are bulky
The bottom line
I love the Incipio Premium KICKSTAND Case with Stylus for the iPad. It's a folio case taken to the extreme. More protection. More kickstand. More angles. And a stylus. It might be overkill for some, but for those looking for a great case with all the bells and whistles, the Incipio Premium is a great place to start.
Now if only they could sneak a multitouch keyboard onto the inside of that flap...!
There are 6 comments. Add yours.
Like the end of the video ;-)
I love mine. Bought it on close out at our SAMs club for $19, and my iPad has not been out of it since.
I pre-ordered this case direct from Incipio. I was excited to use it and really liked it. About two and a half weeks into using it, one of the tabs that holds the ipad completely snapped off. I think it is a major design flaw to have such minimal perimeter support of the device. Good luck to others who have the case. Good idea... Just needs tweaked.
My dad got this at Sams club when he bought his new iPad2.
He likes it, I don't really. The clips that hold the ipad are to few, they need more. They have room for improvement.
Over all, I have seen much worse, so this may be a good choice for some.
I have a Marware, more protection all around.
Here is my review. Check it out!
http://www.youtube.com/watch?v=Psl9EpI4Kss
You're in point of fact a excellent webmaster. The website loading pace is amazing. It seems that you are doing any distinctive trick. Moreover, The contents are masterpiece. you've done a great process in this matter!
