iTunes 12.4 is now available to the public, bringing a number of navigation and design tweaks to the app. The aim is to make iTunes easier to navigate, with a simplified media picker and a persistent sidebar.
iTunes 12.4 arrives with design tweaks and improved navigation
iTunes 12.4 features the following changes:
  • Now enjoy all of your music, movies, TV shows, podcasts and more in a simpler design.
  • Navigation. now you can use Back and Forward buttons as you navigate between your Library, Apple Music, iTunes Store, and More
  • Media Picker. easily switch between Music, Movies, TV shows, and moreā€”and Edit to choose just the items you want.
  • Library and playlists. Use Sidebar to view your Library in new ways. Drag and drop songs to easily add them to Playlists. And Edit Sidebar to show only your favorite views.
  • Menus. Menus in iTunes are now simpler and easier to use. Use the view menu to customize your Library or try context menus to act on specific items.
You'll find iTunes 12.4 in the Updates section of the Mac App Store.
