Moshi IonBank battery charges two iPads simultaneously
Mac and iOS peripheral maker Moshi has announced the IonBank 10K, its first portable battery for charging tablets and cellphones. The device costs $110 and is available directly from Moshi's web site.
The IonBank has two USB ports and outputs 18 watts, making it suitable for everything from an iPod or iPhone to a full-sized iPad. As the name implies, the integrated lithium-polymer batteries hold 10,000 mAh of charge. A button and five-LED gauge show you how much charge is left in the battery, and an integrated USB cable is used to power up the battery when it's not in use.
Both ports can be used simultaneously, but Moshi vaunts the IonBank's "dynamic power sharing" circuitry, which detects the type of device connected and adjusts its charge rate accordingly. If one port isn't in use, all power output will be directed to the other port. A carrying pouch is included.
Moshi plans other IonBank products - smaller-capacity IonBank 5K Lightning and Micro USB versions, which are physically smaller and use integrated cables so you can leave your charging cable behind. Those are planend for release later this fall.
Peter Cohen
Mac Managing Editor of iMore and weekend Apple Product Professional at a local independent Apple reseller. Follow him on Twitter @flargh
More Posts
7
loading...
loading...
48
loading...
loading...
← Previously
weekflow calendar for iPhone review: Use colors, grids, and gestures to better organize your schedule
Next up →
New firmware update fixes battery problems on MacBook Air, MacBook Pro and Retina Display MBP
Reader comments
3 Comments
Not to undermine Moshi, I do love a few of their products, but I highly recommend Anker's Astro 3e battery over this. 10,000 mAh, 2 ports, and 4 adaptor tips. It's also smaller and sleeker, and I found mine for $40 on amazon.
This led me to the Anker® Astro E5 15000mAh Dual USB Port External battery. Gots me one just now for € 36.- at Amazon.de (I'm in NL).
