The Neptor dual battery charger for iPhone and iPad is cute, colorful, and powerful enough to charge up to two of your devices while you're on the go. There a 2.1A USB port for iPads and 1.0A port for iPhones. It's capable of fast charge if you're really in a pinch and even has a flashlight built in if you're also in the dark.
Because it's small, the Neptor only carriers enough juice to charge an iPad almost to full force one time, but it can easily replenish and iPhone. It doesn't come with a built-in Lightning connector, only USB ports, so you'll have to supply your own. Also, colors are limited to blue, green, orange, pink, and red, so if you're a fan of classic black, you'll need to look elsewhere.
I really like the looks of the Neptor. There are alternatives that are bigger and carry more charge but if you want something sleek and just a little sexy, the Neptor is a good choice.
What do you currently use to charge your iPhone and iPad when on the go? Let me know so I can check it out!
