Tylt Band Car Charger review
Tylt has separated itself from the pack of Apple accessory vendors by thoughtful and unique industrial designs; they don't quite look like anything else out there. The Band Car Charger is no different - it's not your average-looking car charger. It's a premium design that commands a premium price. Is the design worth the extra money?
The Band Car Charger measures two feet long - pretty average for an auto charging cable, and sports a flat, wide ribbon cable that doesn't tangle up like thinner cables do. Sheathed in silicone, Tylt makes the Band in four bold colors - very vibrant green, red, and blue, along with a more understated black, if you prefer the traditional look.
The Band plugs into your vehicle's cigarette lighter (or power outlet, as the case may be). It's available in Micro USB, 30-pin Dock Connector and Lightning versions. I opted for the Lightning variant so I could juice up my iPhone on the road.
Tylt Band USB closeup
With 2.1 amp output, the Band has enough power to juice up my iPhone or my iPad. A spare USB port is built into the plug, so you can hook up another sync cable to charge two phones simultaneously. This comes in handy if you are traveling with a companion and both of you want to charge up your devices, or if you happen to have a device that uses a connector other than the one that's built into the Band.
The Band is Apple-certified, so you don't have to worry about it damaging your iPhone or iPad. It is quite pricy for a simple charging cable, even one with a spare USB port built in. Be prepared to pay a stiff premium for the unusual design.
The good
  • Flat ribbon cable won't tangle
  • Colorful options to make the cable easy to find
  • Spare USB port
The bad
  • Expensive
The bottom line
Tylt's Band car charging cable looks much better than the average cable and works well, too, but I question whether the special colors, flat ribbon design and spare USB port really merit the huge price premium.
Peter Cohen
Mac Managing Editor of iMore and weekend Apple Product Professional at a local independent Apple reseller. Follow him on Twitter @flargh
More Posts
15
loading...
16
loading...
48
loading...
loading...
← Previously
After killing the Flappy Bird that laid the golden egg, creator settles into his success
Next up →
CarPlay for Toyota confirmed, and then retracted, for 2015
Reader comments
13 Comments
It maybe a good product, I don't know, never used it nor seen it. But I think it seems a high price for a cable that's to short outa the box to start with. Pass.
Sent from the iMore App
I really liked the product until I saw the price. $43? Yikes! I'd understand if it was a little overpriced (like $20-25), but this is just ridiculous.
This seems like a good idea. I'd buy one if held up. Yes it's more expensive, but it may be a high quality product. Also, I'm sure there's an associated cost of being Apple certified.
Wonder what their actual cost per cable is to make. I am all for a fair profit, but does sound a little much. It may be the fact the cable will last, and you do not need to buy a replacement for a time.
I guess anything that doesn't gray as quickly as the apple wires is worth it. You spend more money buying more cables. So a one time deal is worth it.
I generally don't mind paying a premium for quality apps or accessories but that's a little too steep in my opinion. Get under $30 and we'll talk.
