Charge three devices at once with RAVPower's 26800mAh power bank on sale for $25
The RAVPower 26800mAh dual input USB-C external portable charger (opens in new tab) drops to $24.99 on Amazon thanks to this promotional link that takes 50% off the price and another $3 using the on-page coupon you can clip in your shopping cart. This power bank often sells for around $55, and it's $56 right now without either discount.
The white one (opens in new tab) isn't quite down to this price, but you can get it for 15% off with the on-page coupon, bringing the total down to $43.34.
Plus, the two inputs mean you can recharge it quickly, too.
RAVPower 65W 4-port USB Desktop Charging Station
$34.99 $49.99 Save $15
Keep USB ports close by with this 65W USB Desktop Charging Station by RAVPower. It's equipped with two USB-C ports as well as two USB-A ports. Clip the coupon on its product page and use the following code at checkout to save $15.
RAVPower 10000mAh portable charger dual USB power bank
$9.99 $15.00 Save $5
The ultra slim power bank is only 15mm deep, so it's extremely portable. The battery size of 10000mAh is enough for a full charge of even the largest phones. Can charge two devices at once and has built-in safety features to protect them all.
RAVPower 61W Power Delivery 3.0 USB-C 2-port wall charger
$23.39 $30.00 Save $7
Has 61W output with Power Delivery 3.0. Can charge a MacBook in 2.1 hours. Can detect what's plugged in and deliver fastest possible speeds. Wants to be portable with slim, compact design and foldable pins. Includes built-in safeguards.
RAVPower 48W USB-C Car Charger with Power Delivery 3.0 and Quick Charge 3.0
$14.99 $19.99 Save $5
RAVPower's fast dual-port car charger features a 30W Power Delivery 3.0 USB-C port along with an 18W Quick Charge 3.0 USB-A port. Clip its on-page coupon to snag this deal.
RAVPower 25000mAh solar phone charger outdoor portable charger
$21.99 $46.00 Save $24
Use sunlight to recharge this charger's batteries or plug it in via micro USB or USB-C. The 25000mAh capacity is enough to keep all your devices going outdoors. Includes an LED flashlight and SOS mode for emergencies. Waterproof and dust proof.
This USB-C power bank can be fully recharged in seven to eight hours. It has dual micro USB inputs for recharging so you can top it off quickly. Plus, with one USB-C port and two USB-A ports, you can charge three devices at the same time if you need to. It will even work on something like a MacBook. The 26800mAh battery is a large enough capacity that you'll be able to fully charge your phone multiple times over before you need to find an outlet. The battery charger comes with a 12-month warranty and a carrying pouch.
iMore Newsletter
