Keep 128GB of your personal files on your key ring for just $19
Many people rely on cloud storage these days, which is often a great experience, until it's not. If you don't have an internet connection, or don't want to have to log into an app to get your data, then you'll want to have local copies of the files. Flash drives have been around for quite some time, and they've dropped in price so much over the past few years. Right now, Amazon has the 128GB SanDisk Ultra Flair USB 3.0 flash drive on sale for just $19.49, which is about $4 less than it normally sells for. This puts it within a few cents of its all-time low price.
<a href="https://target.georiot.com/Proxy.ashx?tsid=8428&GR_URL=https%3A%2F%2Famazon.com%2FSanDisk-Ultra-Flair-128GB-Flash%2Fdp%2FB015CH1PJU%3Ftag%3Dhawk-future-20%26ascsubtag%3Dhawk-custom-tracking-20" data-link-merchant="Amazon US""> SanDisk Ultra Flair USB 3.0 Flash Drive
If you like to keep your personal data with you at all times, this 128GB SanDisk Ultra Flair drive is a great way to do it without spending much. This is the lowest price we've ever seen on this drive.
SanDisk Extreme 1TB portable USB-C NVMe solid state drive
$149.99 $240.00 Save $90
Includes a USB-C 3.2 Gen 2 interface for wide compatibility with USB-C devices like computers and smartphones. Has read/write speeds up to 1050 MB/s and 1000 MB/s thanks to the fast NVMe tech. Also IP55 rated for dust and water resistance.
SanDisk 256GB microSDXC memory card
$50.60 $55.00 Save $4
This is Amazon price matching Best Buy. The 256GB card works with any system that can read it and is officially licensed for the Nintendo Switch and Switch Lite. Has read and write speeds up to 100 MB/s and 90 MB/s. Limited lifetime warranty.
SanDisk Extreme Pro 2TB USB-C portable solid state drive
$309.99 $350.00 Save $40
The SSD has powerful NVMe technology with read/write speeds up to 2,000 MB/s. Of course it works with devices not quite capable of that but you won't get speeds as fast either. It comes with a 5-year warranty from SanDisk.
SanDisk Extreme 1TB external USB-C portable solid state drive
$124.99 $140.00 Save $15
Has a 1TB storage capacity and connects easily via USB-C. Even while on the go, you'll get super fast transfer speeds with read speeds up to 550MB/s. The enclosure itself is rugged and resistant to water, dust, and drops. Works with PC and Mac.
SanDisk 1TB Extreme Portable SSD
$155.58 $163.75 Save $8
With high-speed USB 3.0 data transfer, it's quick and easy to get files on and off of the drive. It can transfer a full movie in about 30 seconds, and offers speeds of up to 15 times faster than a USB 2.0 drive does. The sleek metal casing ensures the drive stays protected, and the end has a keyring hook that allows you to easily keep it with you anywhere you go. You can protect your files with a secure password, which is a great addition just in case you happen to misplace it.
It's always best to have your data backed up in multiple locations, because there's nothing worse than losing things that are important to you. Grab one (or two) of these today so that you can start keeping your files safely stored on it.
Get the Windows Central Newsletter
All the latest news, reviews, and guides for Windows and Xbox diehards.
