The Surface Pro is a very different kind of tablet compared to the iPad Pro. It's less tablet and more laptop, and while you can use it for things like consuming media, it's so much more than that.
- Stunning display
- Great hardware
- Built-in kickstand
- Optional keyboard and pen
- Runs a desktop OS
- No USB-C or Thunderbolt 3
- Keyboard is expensive
- Not as good for media consumption
The iPad Pro is an amazing tablet, but if you're looking for something that behaves like a laptop, you won't find it here. If you want just a tablet, this is still the best you'll find.
- Stunning display
- Great hardware
- USB-C
- Amazing app selection
- Expensive
- Runs a mobile OS
- No mouse support or file system
The iPad and Surface are always compared, but the truth is they're two very different devices. Do you want a Windows PC or a tablet to consume media, browse the web, and play casual games on? Sure, you can do work on the iPad, even edit photos and videos, but the workflow is very, very different.
Comparing apples and oranges
It's easy to compare the Surface Pro 6 to the iPad Pro. It's a tablet by design and the iPad is, still, about the best all-around tablet money can buy. It runs Apple's iOS, which is efficient, easy to use, and has an insane app library. The iPad has come a long way since the early days, and it's now not only possible but fairly easy to write, edit photos and videos, play games, and plenty more on an iPad.
Despite all of the pros, it's still limited in a number of ways compared to the Surface Pro 6. iOS, for as good as it is, is still a mobile OS. Windows 10 is what you find on desktop and laptop PCs, complete with full mouse support, something Apple won't give to the iPad.
Surface Pro 6 | iPad Pro | |
Display | 12.3-inch PixelSense (2736 x 1824) | 11-inch or 12.9-inch Liquid Retina (2388 x 1668 and 2732 x 2048) |
Storage | Up to 1TB | Up to 1TB |
Keyboard | Yes (optional) | Yes (optional) |
Pen | Yes (optional) | Yes (optional) |
Price | From $699 | From $749 |
While there are plenty of similarities on a hardware level, when it comes to the experience of using them, it couldn't be more different. The Surface Pro 6 is more of a competitor for Apple's MacBook Air and Pro lineup than it is for the iPad, frankly. So which you should buy depends entirely on what it is you're looking for in your portable computer.
Surface Pro 6 makes a great laptop
The Surface Pro 6 is sold as a tablet, in that there's no keyboard included, but it's actually a full, 2-in-1 laptop. That means Windows 10, access to both Store and legacy win32 apps, a proper file system, mouse support, keyboard, digital inking, the ability to use external drives and accessories, and so much more.
Some of the iPad Pro's media consumption prowess can be applied to the Surface Pro, with apps for services like Netflix, Spotify, Plex, and many others, and Netflix through Microsoft Edge is one of the best ways to enjoy content from the service. However, there are gaps. There's no Prime Video, for example, and the battery life when consuming media will likely fall a good way short of the iPad Pro.
However, that's not really why you'd want a Surface Pro. It offers the very best PC experience in something you can toss in any bag. Write and draw with a pen, or use the Type Cover to get some work done. Anything you would ever want to do on a PC you can do on the Surface Pro 6.
The iPad Pro is a superb tablet
Is the iPad Pro still the best tablet you can buy? Pretty much, but it's not a great tablet for the same reasons the Surface Pro 6 is. Apple's hardware and design is stunning, and the iPad Pro boasts a beautiful display, an almost unnaturally slim form factor, skinny bezels, USB-C connectivity that can even charge your phone, and an optional keyboard and pen.
The biggest difference is the OS. MacOS is a more direct comparison and competitor to Windows 10, whereas the iPad Pro runs iOS, Apple's mobile platform. This means no proper file system, no mouse support, awkward multitasking, and a bunch of other issues you might come across if you're trying to use it like a laptop.
Simple things like dealing with email attachments and renaming files is an extremely convoluted process on the iPad Pro. But that's also by design. Apple doesn't want the iPad to be a touchscreen Mac tablet. But with the scale of the iOS app catalog behind it, the iPad Pro is an incredible tablet. Sure, you can use it to work — many people do — but you'll potentially have to change your workflow, and at some point, if a laptop is what you want, the iPad is going to fill you with frustration.
Do you want a laptop or a tablet?
If it's the former, then the Surface Pro 6 is the one to go for. The iPad Pro is a similar cost but if it's laptop-like features you want, then Apple's tablet will disappoint.
An excellent laptop
Surface Pro 6
Replace your laptop with a Surface Pro 6
The Surface Pro 6 isn't just a great tablet, it's a phenomenal Windows 10 PC for the price of an iPad. This can be your laptop and so much more.
The best tablet
If you're looking for a tablet, maybe for very light work, but mostly for leisure purposes, then the iPad Pro is still the top dog.
A brilliant tablet
iPad Pro
At its best when you're done working
The iPad Pro is probably the best tablet money can buy, if very expensive. However, it's not something that can replace a full laptop in features, at least, not yet.
Keep the 11-inch iPad Pro screen pristine with these screen protectors
The 11-inch iPad Pro is even better when paired with a screen protector. Here are our favorites, no matter which year your iPad Pro is from.
Protect your new iPad with these great cases
Keep your new 10.2-inch iPad in mint condition with these fantastic cases! From keyboards to protection, there are so many options.
Accessorize your 12.9-inch iPad Pro!
Want to outfit your 12.9-inch iPad Pro with the very best? Here are our recommendations.
