The Choetech 10W Fast Charge wireless charging pad with Quick Charge 3.0 AC adapter is down to $15.60 with code P4OVFASY on Amazon. Without the code it's going for $20, and it more regularly sells for around $24. The drop to $20 was already its lowest direct price drop in more than a year, so the extra chunk of change saved by the promo code is just icing on the cake.
No more wires
Not all phones wirelessly charge the same, but Choetech's device can differentiate what you're using and give you as much power as possible.
$15.60 $24.00 $8 off
With coupon: P4OVFASY
The circular charging pad uses an aluminum base to keep your device stable. The compact build and non-slip pad mean you can take it with you for convenient wireless charging anywhere. The pad can deliver a maximum of 10W of power for Samsung devices like the Galaxy Note 10 or Galaxy S10. Wireless iPhones get a max of 7.5W. Other Qi-compatible smartphones get 5W. If you decide to keep this pad in your bedroom, it uses a lighting sensor that lets it know to dim itself when you go to sleep at night. The included AC adapter has Quick Charge 3.0 so you can maximize your charge. This also comes with an 18-month warranty.
