The Toshiba Canvio Advance 2TB portable external USB 3.0 hard drive is down to $48.79 during this special Prime Day deal. The drive normally sells for around $63 and jumps as high as $73. This deal is the lowest it has ever gone. The price only applies to Blue as the other colors are still selling for around $60.
Store More
The deal is about to expire, and the drive has never dropped this low before.
$48.79 $63.00 $14 off
Toshiba's drive uses a compact design so you can take it with you and keep it in your backpack. You can also download Toshiba's optional software to use the drive for security or as a backup. It's covered by a two-year warranty.
