Charging your phone in your vehicle just got a lot easier. Anker's PowerWave Fast Wireless Charging Phone Mount lets you wirelessly charge your phone while you're driving by just placing it in this sturdy phone mount. While this setup normally retails for $60, you can grab it at Google Express for only $36.79 right now when you enter code SEPTSAVE19 during checkout for 20% off. That's almost $10 less than it's currently going for at Amazon. Note that the code only works on your first Google Express order.
Wide compatibility
Anker Roav PowerWave Wireless Car Charger Mount
This phone mount will keep your device in place during the ride and top up its battery wirelessly. It rarely goes on sale and the below coupon won't stick around for much longer, so don't let it pass you by.
$36.79 $45.99 $9 off
With coupon: SEPTSAVE19
The PowerWave combines a phone mount with a Qi-enabled fast wireless charger for one fancy gadget. It can charge up an iPhone 8 or newer at 7.5W and Android phones from the likes of Samsung and LG can benefit from a 10W fast charge on the move. If you are using an advanced enough Android phone to take advantage of the faster charging, you'll want a Quick Charge 3.0 car charger to get top speeds. Fortunately, you can pick one of those up pretty affordably with the money you save. As well as the charging mount, you also get the necessary USB cable for hooking it up to power and two air vent grips with your purchase.
The device will also work through cases so you don't have to take them on and off and it rotates 360 degrees so you can mount your phone in any orientation. You'll get an 18-month warranty from Anker and existing users give it 4 stars based on over 300 reviews.
