Use your phone or your voice to control Genie's ultra-quiet garage door opener on sale for $175
The Genie QuietLift Connect 3053-TKV smart garage door opener is down to $175.48 on Amazon right now thanks to this promotion taking 10% off the price. It normally sells for $195 and does not vary much from that. We haven't seen it go this low before.
You can open this garage door in a dozen different ways including using your voice, your smartphone, the pre-programmed remotes, and a wireless keypad.
The Genie is an ultra-quiet door opener, which makes it great for garages attached to living spaces. You can connect to the garage door opener with your smartphone or even use Amazon Alexa or Google Assistant to control it with your voice. It has a five-piece rail system that snaps together so it's easy to install. Plus, it's lightweight and requires no extra hardware to put together. The system works with garage doors up to seven feet tall and 500 pounds. It comes with two pre-programmed remotes, a wireless keypad that opens the door with a PIN, and a multi-function wall console.
