This dimmable smart LED light strip can be yours at nearly 40% off via Amazon
Gaining more control over the lighting in your home is easy, and it's pretty affordable too. There are tons of smart lighting options out there to choose from, with LED light strips being a great pick to install behind your TV or computer desk. Watching TV or using your computer late at night without some sort of light on in the background can cause a lot of eye strain, but options like the Koogeek Dimmable Smart LED Light Strip (opens in new tab) can help lighten things up and provide a nice ambiance in the process. While it regularly sells for up to $40 at Amazon, today you can pick one up for just $22.99 when you enter promo code L5ATJ6AS during checkout. That saves you nearly $15 off its usual cost and brings this strip lower than it's ever reached without a code before.
Control this smart LED light strip to turn various colors using an app on your phone from anywhere in the world, or with your voice and a compatible smart assistant like Amazon Alexa or Google Assistant.
Koogeek's smart LED light strip measures 6.56 feet long, making it perfect to use with TVs which are between 40 and 60 inches wide. Of course, you could find tons of other scenarios to use it in around your home, from behind your computer monitor or your bed's headboard to your garage or kitchen pantry. Installation is very easy too, thanks to the adhesive backing which makes it simple to stick anywhere that's dry.
Using an app on your phone, you'll be able to control this light strip from anywhere in the world. Adjust its brightness or the color of the strip to set the mood; it's capable of switching between 16 million colors so you can find your favorite shade to match your room. Plus, if you own a device like the Amazon Echo Dot (opens in new tab) or Google Home Mini (opens in new tab), you could begin voice-controlling this LED light strip. It even works with Apple HomeKit.
Koogeek includes a one-year warranty with this LED strip's purchase.
iMore Newsletter
