Smarten up your home's lightning for less with these refurbished Philips Hue starter kits and more
Whether you're already all-in on smart home tech or just getting started, you've probably come across Philips Hue products on your shopping trips. The company offers some of the most well-regarded smart lighting devices on the market, though they often come at a significant cost. That's exactly why you need to jump on rare deals on refurbished products when they come around such as this one-day sale on refurb Philips Hue gear (opens in new tab) at Woot. You can smarten up additional areas of your home without breaking the bank and rest easy knowing you've got a 90-day warranty in the unlikely event anything goes awry.
Refurbished Philips Hue Lighting (opens in new tab)
You can't have a smart home without smart lighting, and Philips Hue gear is regarded as the best. Get your system going with a starter kit, add a wellness lamp, and create an ambiance with a light strip. These refurbs are backed by a 90-day warranty.
Philips SmartSleep wake-up light
$79.95 $100.00 Save $20
Simulates the sunset and sunrise and includes 5 different wake-up sounds. Has an FM radio with snooze and automatic dimmable display. It also includes 10 brightness settings. Help establish a healthy sleeping and waking routine.
Philips Hue white & color BR30 starter kit
$69.99 $120.00 Save $50
The kit includes two multicolor BR30 smart bulbs and the Philips Hue bridge designed to help you unite your bulbs and connect them to your Wi-Fi network. Find the perfect lighting with preset scenes or lighting effects that sync to your movie.
Philips Audio Fidelio X2HR over-ear open-air headphones
Up to 20% off
The X2HR have Hi-Res Audio with 50mm high-def neodymium drivers and an acoustic open-back architecture. They have deluxe memory foam ear pads and a lightweight adjustable hammock with genuine leather.
Philips SmartSleep Connected sleep and wake-up light therapy lamp
$169.99 $200.00 Save $30
Built-in bedroom sensor and smartphone connection helps create ideal environment. AmbiTrack sensor measures your bedroom's temp, noise, light, and humidity. Customize the alarm, light, sound, and sunrise/sunset themes. Has clock and touch display.
Philips goLITE BLU Rechargeable Energy Light
$130.40 $137.79 Save $7
For those new to Hue, the sale features a White Ambiance A19 2nd Gen 2-Bulb Starter Kit (opens in new tab) at $61.99. It comes with smart LED bulbs as well as the necessary hub to get them set up (and add more lights later). You'll receive a smart dimmer switch, too. Once up and running, you can control the lights with the switch or remotely from your phone. You can also set timers and schedules to automate your lights and even make it seem like someone is home even when you are away. If you have a smart speaker like the Echo Dot (opens in new tab), you can use just your voice to adjust your lighting too. This bundle is usually nearer $110 if purchased brand new (opens in new tab). There's a refurb White A19 starter kit with a bundled light strip (opens in new tab) for $44, too.
If you're already using Hue elsewhere, you can still use this refurb sale to add some ambience to another area of your home with a discounted 4-pack of White A19 bulbs (opens in new tab) for only $32. The sale also features the Philips Hue White Ambiance Wellness Lamp (opens in new tab) for $51. It usually goes for as much as $100 (opens in new tab) brand new.
Shipping is free at Woot if you log in using your Amazon Prime (opens in new tab) account, otherwise it's an additional $6 fee. Now's a good time to sign up for Amazon Prime if you aren't already a member with Black Friday deals on their way.
iMore Newsletter
