Add Philips Hue smarts to more rooms in your home with 4 white bulbs for just $8 each
Lucky customers can save $14 on this Philips Hue A19 White smart bulb 4-pack (opens in new tab) at Amazon right now, dropping the price down to only $33.59. That's thanks to an on-page coupon offering 30% off, but the coupon is only showing for select customers so your mileage may vary. If you see the coupon, definitely pull the trigger on this deal. The multi-pack usually sells for $47.99 otherwise.
Image (opens in new tab)
Philips Hue white A19 dimmable LED smart bulb 4-pack (opens in new tab)
It's a great time to expand your existing Hue setup or kickstart a new one with this 4-pack at a new all-time low price.
At this sale price, you're getting each bulb for just $8.40 which is super affordable. These dimmable bulbs let you adjust the shade of white that best works for you. They can be controlled using a free smartphone app or integrated to work with other popular smart home devices like Amazon's Alexa (opens in new tab), Google Assistant, Nest, and more. You do need to have a Hue hub (opens in new tab) set up to use the bulbs, so pick one up if you're just getting started with the Hue range.
If you just want an extra bulb or two and don't want to pay for four, you can take advantage of this limited-time Woot deal offering individual bulbs for $9.59. But let's face it, you're going to want more Hue bulbs at some point so you may as well get the 4-pack even if you don't need them all yet.
Adam Oram
