Add to your smart lighting with this Philips Hue white bulb on sale for under $10
Woot has a single Philips hue white A19 LED smart bulb (opens in new tab) on sale for $9.59 for a limited time. This same bulb sells for around $12 on Amazon (opens in new tab) with spikes as high as $15 as you can see at other retailers like Home Depot (opens in new tab). It never drops this low, and if you use your Amazon Prime (opens in new tab) membership you can avoid Woot's mandatory shipping fee.
Image (opens in new tab)
Philips hue white A19 single LED smart bulb (opens in new tab)
The bulb can be controlled from an app on your phone, and if you have the Hue Hub you can also add voice control through your smart home ecosystem.
Philips Hue Refurbished Smart Home Sale
(opens in new tab)
Prices Vary
Today only, Woot is holding a sale on refurbished Philips Hue smart home products, from smart bulbs and strip lights to the Philips Hue bridge which makes them all work together. A 90-day warranty is included, too.
Philips Hue White & Color Ambiance Signe table lamp (Requires Hue Hub, Works with Amazon Alexa, Apple HomeKit and Google Assistant)
(opens in new tab)
$114.97 $159.99 Save $45
Philips Hue Starter Kit with Dimmer Switch
(opens in new tab)
$104.95 $99.99 Save $-5
(opens in new tab)
$159.99 $159.99 Save $0
(opens in new tab)
This single smart bulb can become the gateway to your new smart lighting obsession or just help you round out adding every last light in your house to your smart home. If you haven't bought any Philips Hue bulbs before, you will need a Hue Hub (opens in new tab) to go with this bulb. The hub lets you unite this bulb with any future Philips Hue products and serves as a connection to your smart home device like the Echo Dot (opens in new tab). Use the Philips Hue app to set schedules to turn the light on and off so your home is lit up as you walk in the door or looks like you're home when you're not. The bulb has a brightness of 800 lumens and will last for up to 25,000 hours.
Of course if you are a Prime member, you should visit our Prime Day hub because we expect to see a lot of smart home deals during that event.
John Levite
