Turn your room many colors with the discounted DreamColor Smart LED Light Strip for $25
One easy way to change up any room's look is with an LED light strip, and Govee makes some of the most highly-reviewed models on Amazon which include features like app control, music synchronization, and Alexa voice control compatibility. The DreamColor 16.4-foot LED Light Strip (opens in new tab) is one option that includes all of those and more, and today you can snag it for just $24.79 when you enter promo code AQBTQYKV during checkout. That saves you $15 off its regular price and brings it down to one of its best prices in history.
Image (opens in new tab)
Govee DreamColor 16.4ft LED Strip Lights (opens in new tab)
The DreamColor LED light strip is unlike most others as different portions of the strip can turn different colors, rather than sticking to one solid shade. It's quick to install with its 3M adhesive backing that sticks to dry, flat surfaces easily.
This LED light strip features an adhesive backing that makes it stick easily to wherever you've decided to install it. Once set up, you'll be able to use the Govee Home app on your smartphone to change its color, schedule when it's on or off, and more from anywhere in the world. You can even set up different portions of the light to turn different colors, which is a feature you won't find on many other LED light strips. It fits in so many places too, from behind your TV to in the garage, a bedroom, or your office.
If you're not interested in this light strip's app functionality, there's an even more affordable version of this strip that is controlled with an included IR remote and is on sale for just $18 (opens in new tab) currently. It's the same length at 16.4 feet though it's missing a few other features that the model above includes such as Alexa compatibility.
Govee also has a light strip that uses a cigarette lighter plug to power up, making it a perfect option to use in your vehicle. You can snag one today for only $17 (opens in new tab) at Amazon. It comes in four pieces to make installation a bit simpler no matter which vehicle you own.
Alex Smith
