The Rachio 3 8-zone smart sprinkler controller is on sale for $199.99 at Amazon today. That's about $22 off what it regularly sells for. You can also get the 16-zone controller down to $249.99, which is $30 off its street price. Shipping is free for either option.
Water you up to?
Rachio 3 8-zone smart sprinkler controller and 16-zone controller
You might even be able to find discounts with your local utility company just for installing one of these.
$223.85 $255.00 $31 off
These are Rachio's newest controllers. They come with a limited warranty. The smart controller works with smart home platforms like Amazon Alexa and Google Assistant. It has dual-band Wi-Fi and a long-distance Flex radio. The installation is also very simple and will take you less than 30 minutes with no special tools required. Once it's in, the Rachio can monitor and manage how you use your water. Use your smartphone to set schedules, make automatic adjustments for the weather, and more. This is also the only generation of the Rachio compatible with Rachio's wireless flow meter, which adds even more advanced control over your water.
