Pressure washers are great for a variety of outdoor cleaning tasks, helping you to blast grime and gunk off your patio, porch, fence, garage, car, driveway, and much more. They can be a tad bit pricey though, which is why you should pick one up while it's discounted, like the Sun Joe SPX3200 2030 PSI Go Anywhere electric pressure washer. Though it normally sells for around $170 on average, today it's down to just $119.99 on Amazon. That's only a dollar above the lowest we've ever seen it reach. Walmart is offering this same deal as well.
Spray + Save
Sun Joe SPX3200 Go Anywhere electric pressure washer
Whether you need to clean your patio furniture, your driveway, your siding, or something else, this handy electric pressure washer can help take care of the job and save you $50 in the process.
$119.99 $170 $50 Off
It has easy-glide wheels, which means you can maneuver it exactly where you need it. The five quick-connect spray tips help you tackle simple and heavy-duty jobs. The pump will automatically switch off when the trigger isn't engaged to save you energy and prolong its life. Users give it 4.7 stars based on 41 reviews.
