Woot has the Worx WG629 Hydroshot Portable Power Cleaner on sale today for just $69.99. This deal scores you this tool at $35 off its current cost at Amazon and is the lowest we've ever seen it go. Shipping is free if you log in with your Amazon Prime account or it will cost you an additional $6.
SPRAY 'N' SAVE
Worx WG629 Cordless Hydroshot Portable Power Cleaner
The portable Hydroshot connects to your garden hose at home and can be used in so many ways, from cleaning outdoor furniture to clearing your gutters.
$69.99 $104.94 $35 off
This portable power cleaner can be used all around the outside of your house and is perfect to use for washing cars, watering plants and flowers, and cleaning patio furniture. It attaches to a garden hose or can draw water from a source like a pool or lake. With dual mode operation, you can switch from cleaning to watering in a flash. It features a max water flow rate of 0.5 GPM with a maximum PSI of 94. It includes five spray angles: 0 degrees, 15 degrees, 25 degrees, 40 degrees, and shower.
Your $70 gets you the cleaner as well as an included battery and 20-foot hose to reach longer distances, or you can add on the cleaning accessory kit for $20 more. That gets you a cleaning brush, bottle connection accessory, window squeegee, and more. Depending what you intend to use it for, you may or may not need the extras. Not sure what you could use the Hydroshot for? Worx has a great list of 10 unexpected ways to make the most out of its purchase.
