evasi0n 1.1 released with bug fixes for Weather app problems and reboot issues
evasi0n has just been updated to version 1.1 to address issues some concerning long reboot times and problems that were causing the Weather app to crash. If you've already jailbroken on iOS 6 or 6.1, there's no need for you to do anything if you aren't having issues. If you, however, haven't jailbroken yet, you'll want to download the new version first.
Over on Twitter, planetbeing has pointed out that if you're already jailbroken, there isn't anything new that requires you to rerun evasi0n -
evasi0n 1.1 has been released on the site with the latest fixes. You may have to clear your browser's cache to see it. Note that you do not need to download evasi0n 1.1 if you've already jailbroken.
If you haven't already jailbroken but plan to do so, just make sure you download the updated version before performing the process. If you've already been to the evasi0n website, you may need to clear your internet cache to see the update or you can grab it from our downloads page linked below.
Source: evasi0n.com
Additional resources:
Allyson Kazmucha
Help and how to editor for iMore. I can take apart an iPhone in less than 6 minutes. I also like coffee and Harry Potter more than anyone really should.
More Posts
4
loading...
4
loading...
102
loading...
loading...
← Previously
Twitter for iPhone and iPad improves Search and Discover
Next up →
ZEN & TECH live! 7pm PT/10pm ET: Fitness Month special!
Reader comments
22 Comments
The same fixes and updates are available through Cydia, for those that are already jailbroken with evasi0n. As planetbeing tweeted: "There is nothing in evasi0n 1.1 that is not already in Cydia."
Also, (at least in Firefox on Windows), instead of manually clearing any caches or anything in order to see the new version on the website, just press Ctrl+F5 while on the site.
So what's the fix here? I've completed the JB. I went to the site to download the update & it says I'm already JB. How does the weather app get fixed if I'm already jailbroken?
Edit - Nevermind. I did the update(s) in Cydia. Phone rebooted & it's fixed.
JailBreaking is an excacting science... We will continue to watch..and wait.
I'm somewhat shocked at the number of issues on the Evasion Q&A page.
Makes for informative reading,observation and discovery..watch..and wait..
That's the preference..
I'm watching, as well. Mine wasn't broken, so I didn't fix it... at least until all these kindhearted souls help me out by doing the testing for me. That means I stay on 5.x, for a while longer, but that's ok.
Mine was a total flail! Not sure which update got me today as there are six apps as well as the evasion update in Cydia when i checked today...somewhere along the way I got stuck in safe mode after doing the Cydia update and no matter what I tried I couldn't come out of it! Big bummer! Despite following the recommendations including Using the crash log app I couldn't get it out of safe mode so I'm currently doing a restore and will have to jailbreak again and reload those apps! Too bad as the initial jailbreak Monday was very easy and so far everything was working better than I could've hoped! So be careful out there! :)
Most likely one of the JB apps you added is not yet compatible. Just add them one by one and see when the crash occurs. You may just have to wait for that JB app/tweak to be updated to meet your iOS requirements. Hope that helps.
I did an upgrade on cydia but the weather app crash has not fixed :(...the evasiOn version upgrade shows 0.2-3 that is currently installed...is this right?
I've a weird issue. Everything was working fine with the first version. Then this 'fix' came out in cydia, I did the update and now I don't have the weather app itself....!!
Mine isn't working. I have installed the UIkit that fixes the bug, but i have to uninstall the appsync. I don't have any other update to do.
Edit: Ok, i've tried one thing, uninstalled the appsync and rebooted the device, that worked for me, but then i don't have the appcake installed, when i installed again it install the appsync again, after rebooted the device the weather app stop working again. The appsync is the problem.
As a Galaxy Note Owner.. I can honestly say, this is starting to sound like an "Android" forum.
Thank You All.. for your candid input.. It serves as confirmation that I am not touching my 64gb iPad Mini with this quiant exercise in expression... Looks like Apple got it right the 1st Time. :-)
I've now jailbroken with 1.1 and everything is working well for me. I did turn off my passcode lock as suggested on the Evasi0n site. Can I turn it back on now that the process is done, or do I need to leave it off with this JB?
I did so and everything seems to stll be working okay. Was just worried because when I tried with 1.0 I had a passcode and ran into the reboot issue.
Thanks!
I jailbroke with the original version of evasion before the updated 1.1 came out. Then i did all the cydia updates but the weather app is still not opening??? Any thoughts?
Look at planetbeing's Twitter timeline, there are some fixes explained. You probably have or had AppSync installed at some point, which prevents the fix from being applied. Or check JailbreakQA or reddit.
Oh well, i rather have my jailbreak and appsync then the weather app. I can always download another weather app. Let me know if the fix ever comes out.
Thanks
