Stock up on Anker's 3-foot USB-C to Lightning cables while they are discounted to $15 today
The black Anker Powerline+ II USB-C to Lightning cable is down to $15.39 on Amazon as part of a wider sale on Anker charging accessories. We've never seen this cable go lower but the sale is limited to today only, so you'll have to act fast if you want to pick one (ore more) up.
This is a double braided nylon cable designed to last forever, and it comes with Anker's lifetime warranty in case it doesn't. The sale knocks over $6 off the black version.
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Because this cable has Power Delivery, you can use it to fast charge your Lightning-based iOS device from a USB-C charger or power adapter. Being MFi-certified means it has passed Apple's strict quality testing and is approved for use with your iPhone or iPad. It is nylon braided for added durability and lasts much longer than ordinary cables. In fact, it's rated for a lifespan of over 30,000 bends and Anker is so sure this cable will last that it is backed up with a lifetime warranty.
If you're not yet all-in on the USB-C future, you can pick up a 10-foot USB-A to Lightning cable for just $9 in today's sale.
