Anker's new USB-C to Lightning cable is already on sale for just $12
Apple only just opened up the certification process for USB-C to Lightning cables, and one of our favorite accessory makers already has one on the market. Right now you can pick up Anker's USB-C to Lightning Powerline II cable for just $11.99 in your choice of black or white. This is one of the first third-party cables to be released that is certified from Apple, which means it passes all the safety tests required to properly charge your device. Normally, it sells for about $16 and today's price drop marks a new all-time low. The deal is only available for the rest of the day, though, as it is part of Anker's huge one-day sale on all manner of charging accessories.
Anker USB-C to Lightning Cable
At this price, you're going to want to get a couple of these MFi-certifed cables and make the most of your iPhone's fast charging capability.
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
It's designed to withstand 12,000 bends without any issue, and Anker is so sure of its long-lasting performance that the company backs it with a hassle-free lifetime warranty. The cable can support USB-C Power Delivery up to 87W with the right power adapter, allowing you to fast-charge your iPhone. If you've upgraded to a newer MacBook and don't have a full-size USB port anymore, these cables are an absolute necessity.
Odds are you'll want to grab a couple of these at this price so you have one for the house, one for the car, one for the office, and even one to keep in your travel bag.
