The August Smart Lock Pro and Connect Wi-Fi Bridge are on sale for $149.99 at Best Buy. The deal is only good today so latch onto it while you can. The price drop is also available in Black.
You can also find this deal on Amazon. It's a direct price match of Best Buy. Before today, the August Smart Lock Pro dropped to around $160 in mid-November, but other than that it has mostly sold for around $180 or more. Today's price is the best deal from either retailer.
Open sesame
August Smart Lock Pro + Connect Wi-Fi bridge
You can lock or unlock your door from your phone. With the Connect, you can monitor it from anywhere. Always know when your door is closed and locked. Control it with your voice using your smart home. You don't have to replace your current deadbolt.
$149.99 $180.00 $30 off
August 4th-generation Wi-Fi smart lock
More compact than previous versions but just as feature rich. Doesn't require an additional bridge to connect to Wi-Fi. Get full remote access and voice control out of the box. Attaches to your existing deadbolt, too, so no key change.
August Smart Lock Pro with Connect Hub
Amazon is bundling the August Smart Lock Pro with the Connect Hub at a discount of 50% off its regular price while supplies last! This Cyber Monday exclusive deal brings this two-piece bundle down to its lowest price in history.
August Smart Locks and wireless bridges
Get the 3rd-gen Smart Lock or Smart Lock Pro and Connect hub for Alexa compatibility on sale for just $149.99 today. Can automatically lock your door. Use your voice to do it. Set it up to detect your presence and automatically lock or unlock.
August Smart Lock Pro + Amazon Echo Dot
This bundle at Amazon includes the August Smart Lock Pro with its Connect Wi-Fi bridge plus a 3rd-gen Echo Dot to control it with. It's an awesome bundle with a $125 discount if you buy it during Prime Day.
August Smart Locks
There are two different options available here, the Smart Lock and the Smart Lock Pro with Wi-Fi bridge. These are up to 63% off thanks to this one-day sale, so don't miss out.
August's 3rd-gen smart lock gives you wide-ranging control over your front door. With August's Door Sense, you'll be able to know if your door is closed and locked from anywhere. And thanks to the app, if you find the door was left unlocked you can lock it even when you've already made it to work.
You'll be able to control access, too. For example, you can create guest access for visitors that only lasts for a few minutes or a few weeks. You can track the door's activity 24/7, too. The lock works with most single-cylinder deadbolts, and you'll be able to keep your existing locks and keys. You can set it up to lock automatically behind you and unlock when you approach. This lock uses the Z-Wave Plus wireless protocol, so you will need a hub to connect to other systems.
The lock on its own uses the Z-Wave Plus wireless protocol. You would need some sort of hub to connect it to the rest of your smart home network, and it's a good bet you aren't already using one that supports Z-Wave. But that's why you get the Connect in this bundle. It creates the Wi-Fi bridge you need so you can connect your smart lock to your Wi-Fi network and, by extension, the rest of your smart home. Gain voice control through Amazon Alexa, Google Assistant, or Apple's Siri.
