Every home needs smart plugs, and this TP-Link two-pack is $25 off today only
We've been spreading the smart plug gospel for months. Smart plugs are one of the easiest ways to retrofit your home to work with newer, more intelligent tech. Thanks to this deal, they're affordable too. B&H has two TP-Link HS107 Wi-Fi Smart Plugs on sale for $34.99 shipped, saving you $25 off the usual price. Shipping is free. If you only want one plug, you can grab an individual unit at Amazon for just $19.49 at the moment though it's still better value to pick up the 2-pack at B&H if you want more than one. You have to be quick, though, as the deal is only good for today.
TP-Link HS107 Wi-Fi Smart Plug 2-Pack
These smart plugs each have two outlets so you can transform one AC outlet into two. They connect to your Wi-Fi network, so setup is simple. Each plug allows you to turn your regular electronic appliances on or off from anywhere in the world.
TP-Link Archer AX3000 Wi-Fi 6 wireless router
$99.00 $130.00 Save $31
Wi-Fi 6 promises speeds up to three times faster than previous generations with four times the bandwidth capacity and 75% lower latency. The router has MU-MIMO tech to cover multiple devices connected at once and Ethernet for wired connections.
TP-Link Kasa KP400 smart outdoor plug 2-pack
$29.99 $50.00 Save $20
Get free shipping with your Prime membership. Each plug has two outlets that can be controlled together or individually. Use your phone or voice control with Google Assistant or Amazon Alexa to control them from anywhere. Weather resistant.
TP-Link Archer A20 AC4000 Tri-Band Wi-Fi router
$139.99 $200.00 Save $60
With a tri-band radio, MU-MIMO technology, Beamforming, link aggregation, and more, this router is perfect for homes with a dozen different devices all trying to connect at once. It supports Windows, Mac, and Linux. Includes a 2-year warranty.
$16.99 $25.00 Save $8
With two outlets you can control two outdoor devices either together or individually. And you can do it from anywhere using your phone or voice control through Google Assistant or Amazon Alexa. Weather resistant with long Wi-Fi range.
TP-Link Archer C7 AC1750 Wi-Fi 5 dual-band router
$49.99 $80.00 Save $30
This great little budget router is capable of data transfer speeds up to 1750 Mbps with 2.4GHz and 5GHz wireless bands. Also has four Ethernet ports for a wired connection. Includes a quick and easy setup wizard.
These smart plugs each have two outlets so you can transform one AC outlet into two. They connect to your Wi-Fi network, so setup is simple. Each plug allows you to turn your electronics on or off from anywhere in the world using the free Kasa app for your iOS or Android device. You'll be able to see if you left something on while you're away from home, or schedule a device to turn on just before you arrive back from a trip. These are great too because they're small enough where you can plug two into the same wall receptacle, unlike other bulkier smart plugs that obstruct the unused outlet. You can control them with the free app, or with your voice if you have an Alexa or Google Assistant gadget around.
Existing owners rate TP-Link smart plugs very highly with an average of 4.3 out of 5 stars based on almost 14,500 reviews at Amazon.
B&H is also offering a couple of other smart home essentials on sale today only. The promotion includes the 2-pack of TP-Link HS200 Smart Wi-Fi Light Switches which is down to $34.99 from $60 and the TP-Link LB200 Smart Wi-Fi LED Bulb at $5 off.
