Skip to main content
Every home should have one of these discounted smart garage door openers
It's no surprise that we are huge fans of smart home devices, and there are a ton of them out there that you can pick between. Something that you may not have considered adding smarts to is your garage door, but that is about to change. Right now, three of the best options when it comes to smart Wi-Fi garage controllers are on sale, and the best part is that with most of them you can use all of your existing garage door hardware instead of needing to buy a new opener.
NEXX Smart WiFi Garage Door Opener
The first option comes from NEXX, and this price is only available for today, as it's a one-day sale at Amazon. You can save $30 thanks to this sale, dropping it from $99.99 down to $69.99. This is the most expensive option of the three, but it also offers a bunch of great features to help justify the cost. There's no extra monthly charge to use voice assistants to control it, there's a web app that can be used to control it, and of course a free mobile app for both iOS and Android.
It's easy to install and works with most garage door openers. Be sure to check out the list of compatible openers to ensure it will work with yours before purchasing.
Meross Smart Garage Door Opener
Next up is the most affordable option on the list, which comes from Meross. It's a highly-rated unit that drops down to just $38.49 at Amazon when you use coupon code A77MQFN9 during checkout. This is arguably the easiest of them all to install, and it works with a wide variety of openers.
Like the NEXX option, this one works with Amazon Alexa, Google Assistant, and IFTTT without the need for an additional hub. There's also a free app that you can use to control the door and check the status, and it has tons of custom notification options available.
Chamberlain MyQ Smart Garage Hub
The final option comes from Chamberlain, which is one of the biggest names when it comes to garage door openers. This kit works with any garage door opener that was made in 1993 or later that has standard door safety sensors, but it does lack some of the features the others have. In order to unlock the smart assistant features you'll need to pay a fee, which is $1 a month or $10 per year.
While that's a bit of a bummer, it's worth noting that this is the only opener on this list that works with Amazon's Key delivery service, which allows the driver to put your packages safely in your garage. It's a balance, and it really just depends which features are most important to you, but this is also a great option. You can also bundle it with an Amazon Cloud Cam (opens in new tab) for $124.99.
You can't go wrong with any of the options that are on this list at these prices. Whether you want the most affordable one or the one with the most features, there's something here for everyone.
