Kasa's discounted outdoor smart plugs work well with holiday lights
Smart plugs are one of the most essential gadgets for any proper smart home setup, but you aren't limited to only using them indoors. Smarten up your backyard or patio with a smart plug rated for outdoor use and your whole property can get a bit more intelligent. Right now TP-Link's Kasa Smart Wi-Fi Outdoor Plug (KP400) (opens in new tab) is down to just $29.99 at Amazon. No coupon clipping or promo codes are necessary to get in on the discount. This is a match of the best price we've seen for this particular item, and it saves you about $10 off the price of the plugs otherwise. You'll get free shipping as well, though items might arrive faster if you use Amazon Prime (opens in new tab).
TP-Link Kasa Smart Wi-Fi Outdoor Plug (KP400) (opens in new tab)
Save over 20% on these well-rated outdoor smart plugs. They're waterproof, compatible with various voice assistants, and controllable via your smartphone no matter where you're at in the world.
This outdoor smart plug features dual outlets which can be controlled together or individually using a free app on your smartphone. It's built to withstand harsher weather conditions, too, making it suitable for landscape or holiday lighting, swimming pool pumps, fountains, and more, thanks to its IP64 rating and an included weather-resistant cover to help when the plugs are not in use. Plug in your backyard lights and you'll have a way to turn them off when you're in bed and the switch is halfway across the house. Use the plug in conjunction with your Christmas lights and you can ensure that your home is looking festive, even if you're over the river and through the woods.
Using the Kasa Smart app, you'll be able to power the plug on or off from anywhere in the world, set schedules, and more. You can also group this smart plug with other Kasa smart plugs in your home so you can control them all simultaneously if you'd like. Plus, if you have a device like the Amazon Echo Dot (opens in new tab) or Google Home Mini (opens in new tab) at home, you can voice control the smart plug and even give each outlet its own name.
iMore Newsletter
