The Lutron Caseta wireless smart lighting dimmer switch starter kit is down to $124.90 on Amazon. This kit normally sells for around $160. It hasn't dropped from that price since the last deal we shared, which was way back in October last year. While this is a few bucks off that deal, it's still one of the best prices we've ever seen and one that's likely to disappear for a few months when it expires.
Get going!
Lutron Caseta smart lighting starter kit
You can truly turn your entire home into a smart machine. It's amazing the control a kit like this can give you, and it's discounted for the first time since last year.
$124.90 $160 $35 off
The starter kit comes with two dimmer switches, two Pico remote controls, and the Lutron Caseta smart bridge. The bridge is the hub for all your Lutron devices. Once you've connected the switches to the hub, you can then add the hub to your smart home ecosystem (Amazon, Google, Apple), and control it with your voice. Lutron has been getting more and more advanced, too, so you'll find tons of other switches and such you can add to this system.
Save big on these VPN services ahead of Black Friday
The kit is easy to set up, and once you do you can use the remote controls to access the lights from inside the house or the free Lutron app to control them from anywhere. They can also be tuned to automatically adjust to the seasons or Daylight Savings Time, and the Smart Away feature helps make it look like someone is still home when you're traveling. Each dimmer switch can control up to 17 bulbs. The kit has 4.5 stars based on 273 reviews.
