Meross is offering iMore readers an exclusive deal on its Smart Wi-Fi Dimmer Light Switch at Amazon! Simply clip the coupon on its product page and enter promo code THRFTR35OFF during checkout to add it to your order for only $16.84. That'll save you $15 off its average cost there; it's fluctuated between $30 and $40 for the last couple of months.
This smart dimmer light can be installed in just 15 minutes, and once set up, you can begin controlling it and scheduling its usage all with the Meross app on your iOS (or Android) device. It's even capable of being voice controlled if you have a device such as the Amazon Echo Dot or Google Home Mini. Unlike its competitors, no hub is required to use it either.
What was it like working on the set of 'Cherry'?
I worked on the set of the film 'Cherry' which will be released on Apple TV+ on March 12. It was a pretty incredible experience; here's what it was like behind the scenes.
March 23 Apple event could bring AirTags, new iPad Pro, AirPods, Apple TV
Apple might be set to lift the lid on a ton of new hardware.
Apple VR leak suggests 2022 release date, key features
A new research note from Apple supply chain guru Ming-Chi Kuo indicates Apple's VR headset is coming next year, and will be highly integrated with products like Apple TV+ and Apple Arcade.
Automate your home with the best HomeKit smart plugs around
If you're new to home automation, a smart plug is a great first step in building out your connected home with its simple plug and play design. Here's our guide to the best smart plugs for HomeKit that you can buy.
