Choose a color to set the mood with TP-Link's Kasa A19 Smart Bulb on sale for $25
By Alex Smith published
Controlling a smart bulb is easy, especially one like TP-Link's Kasa Smart A19 LED Bulb (opens in new tab). It doesn't even require that you buy a hub; all you have to buy is the bulb to get started, and luckily they're on sale today at Amazon for just $25.49 (opens in new tab). Considering they're regularly sold for around $33 on average, today's deal saves you over $7. It's also just 50 cents above the lowest they've ever reached without a coupon there. If you're lucky, you may even see a coupon to save an additional 30% on this purchase.
Voice control this smart bulb using an Amazon Alexa-enabled device, or turn it on and off using your phone and the Kasa app.
$25.49 $32.80 $7 Off
This smart bulb connects to the Wi-Fi network in your home, which then allows you to control it from anywhere in the world by using the Kasa app on an iOS or Android device. That means you'll be able to turn on or shut off the light even while you're miles away. It's compatible with Amazon Alexa, Google Assistant, and Microsoft Cortana too, meaning you can use a device like the Echo Dot (opens in new tab) to voice control your new smart bulb.
The bulb can change colors based on what you select in the Kasa app, and can be scheduled to power on or off at specific times of the day. Nearly 800 Amazon customers left a review for it resulting in a rating of 4.1 out of 5 stars (opens in new tab).
