Control more of your home with two TP-Link Kasa in-wall smart outlets on sale for $50
You know why I like TP-Link's smart home accessories? They're easy. Easy to use, easy to set up. They don't fall apart or get complicated when things go wrong. They just work and add convenience to my life. Well, TP-Link has something new. The KP200 Kasa smart Wi-Fi in-wall power outlet, which is on sale for $49.99 in a two-pack at B&H. The outlet has only been available since March and hasn't seen any real deals. A single pack goes for $40 on Amazon and other retailers, so you're saving $30 by buying two at this discounted price.
TP-Link KP200 Kasa smart Wi-Fi in-wall power outlet 2-pack
You're saving $30 buying two of these outlets at a discounted price instead of buying them individually. Get rid of the middle man of smart plugs and just convert your regular outlets into something smarter.
TP-Link Archer AX3000 Wi-Fi 6 wireless router
$99.00 $130.00 Save $31
Wi-Fi 6 promises speeds up to three times faster than previous generations with four times the bandwidth capacity and 75% lower latency. The router has MU-MIMO tech to cover multiple devices connected at once and Ethernet for wired connections.
TP-Link Kasa KP400 smart outdoor plug 2-pack
$29.99 $50.00 Save $20
Get free shipping with your Prime membership. Each plug has two outlets that can be controlled together or individually. Use your phone or voice control with Google Assistant or Amazon Alexa to control them from anywhere. Weather resistant.
TP-Link Archer A20 AC4000 Tri-Band Wi-Fi router
$139.99 $200.00 Save $60
With a tri-band radio, MU-MIMO technology, Beamforming, link aggregation, and more, this router is perfect for homes with a dozen different devices all trying to connect at once. It supports Windows, Mac, and Linux. Includes a 2-year warranty.
$16.99 $25.00 Save $8
With two outlets you can control two outdoor devices either together or individually. And you can do it from anywhere using your phone or voice control through Google Assistant or Amazon Alexa. Weather resistant with long Wi-Fi range.
TP-Link Archer C7 AC1750 Wi-Fi 5 dual-band router
$49.99 $80.00 Save $30
This great little budget router is capable of data transfer speeds up to 1750 Mbps with 2.4GHz and 5GHz wireless bands. Also has four Ethernet ports for a wired connection. Includes a quick and easy setup wizard.
So you know how you can attach a smart plug to a regular outlet, plug something into it, and then control it from your phone or with your voice? Well, these in-wall outlets just skip the plug part. With two places to plug in, you'll be able to control whatever devices are plugged in. Plus, you can control them at the same time or individually. Use your smartphone and the Kasa app to turn the plug on or off, set schedules, create scenes, and more. You can also connect the outlet to your Amazon Alexa, Google Asistant, or Microsoft Cortana smart home device and control it with your voice.
