The Tribit 24W portable Bluetooth speaker is down to $51.99 on Amazon when you combine the code UVL2GRUA with a $4 off on-page coupon. The speaker almost exclusively sells for $70 and rarely drops from that price.
Listen and Enjoy
Tribit 360-degree surround sound 24W portable Bluetooth speaker
This speaker will help you sit on a wall contemplating reality like that girl over there. Stack the two coupons to save big.
$51.99 $70.00 $18 off
With coupon: UVL2GRUA
Tribit speakers always do good things with audio. This one is no different. With the Tribit speaker you'll get 360-degree immersive sound filled with crisp treble, detailed mids, and a resonating bass. In fact, if you need more bass, the speaker has XBass tech that will fill the room. All you do is press a button. It has advanced IPX7 water resistance that means you can take this speaker to the pool or in the shower. It can withstand water for up to 30 minutes and in water three feet deep. The battery life lasts up to 20 hours, and the Bluetooth range works up to 60 feet.
Existing owners rate it highly with an average of 4.5 out of 5 stars based on over 400 Amazon reviews. I personally own this speaker and, while I have only had it for a few days, I can tell you it sounds great for its size and its construction is of a high quality. I still need to try throwing it in a pool, though.
