Find yourself with an Echo Dot or two after last week's massive Prime Day sale? At $22 each, we don't blame you, and this next deal makes for a brilliant way to put some of those savings to use. WALI's Wall Mount Stands for Echo Dot make it simple to mount your new Echo Dot speaker on an unused power outlet in your home. They're even on sale right now at Amazon, giving you the opportunity to snag two for just $8.49 in your choice of white or black. That's like paying just a little over $4 for each one; they normally sell for $11 together.
Sound Advice
WALI Wall Mount Stand for Echo Dot (2-Pack)
These wall mounts hang from your Echo Dot's power brick while it's plugged into the wall to direct the speaker's sound towards you rather than up towards your ceiling. Today's price is the lowest we've ever seen this two-pack reach, too.
$8.49 $10.99 $3 off
These mounts are designed exclusively for use with the latest, 3rd-generation Echo Dot smart speaker, helping to direct the sound towards you rather than up towards the ceiling. Each mount wraps around your Echo Dot's power adapter while it's plugged into the wall to hold your speaker steady against it. They help keep them secure while ensuring they don't block any of the sound, and they also have a cable management spot for the Echo Dot's power cable. WALI even includes a 10-year warranty with the purchase.
If you still haven't gotten your hands on an Echo Dot speaker, there's one last deal available this month that you shouldn't miss out on. Normally, the Echo Dot speakers cost $50 each, but for a limited time, adding two to your cart and then entering promo code DOT2PACK during checkout will bring your total to just $50! That'd be like paying just $25 for each one, which isn't too far off from the deal we saw during Prime Day.
