The Anker Soundcore Life Q20 Bluetooth headphones have fallen to $39.99 at Amazon. These headphones don't drop from their $60 price very often and the current discount matches its steepest ever.
Noise. Cancelled.
Anker Soundcore Life Q20 Bluetooth over-ear noise-cancelling headphones
These are hybrid Bluetooth headphones, which reduce ambient noise up to 90% thanks to 4 active noise-cancelling mics. They have 100% stronger bass using Anker's BassUp technology and 40-hour playtime on a single charge, which is impressive.
$39.99 $59.99 $20 off
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics and can let it in when you need to hear. Battery lasts up to 40 hours with ANC on and 60 hours with it off. First in the series to use USB-C.
Anker Soundcore Liberty Air X true wireless earbuds best buy
These earbuds include expertly-tuned graphene drivers. They have exceptional sound accuracy and great clarity thanks. The aptX codec helps deliver music wirelessly without interference. Get 7 hours on a single charge and 28 hours with the case.
Anker charging cables, wall chargers, and solar power banks
Never go without power. Get an Anker power strip with a USB-C port, a USB-C to USB-C charging cable, a USB-C wall charger, or even a 10000mAh portable battery charger with a built-in solar panel so you can get power even in the great outdoors.
Anker wall chargers, USB-C cables, wireless charging pads, and more
The sale includes USB-C to USB-C cables for as low as $11, a five-port wall charger with Quick Charge 3.0 ports for just $26, and even an Anker power strip that includes multiple USB ports and AC outlets for $25 off. All prices are good today only.
Anker Roav C2 Pro dash cam black
Has a 145-degree wide-angle lens that can view up to four lanes of traffic. Includes a Stony Starvis sensor and NightHawk tech for capturing everything, even license plates, day or night. Has a 3-inch display and built-in G sensor.
These headphones have an active noise-cancelling system that helps eliminate ambient noises. Whether that happens to be children screaming, an airplane's engine, or some other obnoxious sound you want to get rid of, you can focus on just your music with the Q20.
You'll also get some Hi-Res Audio with the large, custom-designed 40mm drivers that produce exceptional sound. The high frequencies can reach up to 40 kHz, and the headphones have BassUp technology which can really get those lower frequencies thumping. It actually analyzes the sounds in real time to instantly strengthen the bass output so you can feel it in your chest. Just double press the play button to activate it.
On top of all this, the Anker headphones still last for up to 40 hours. That's with Bluetooth and the hybrid active noise-cancelling activated. The Q20 use Bluetooth 5.0 tech so you won't notice any latency in your Bluetooth streaming, but they do come with a 3.5mm aux cable so you can plug in when you need to. That helps preserve the battery, and you can extend the life of the charge up to 60 hours if you wire in and turn off ANC.
The design of the headphones includes memory foam earcups that will mold around your ears every time you put them on. The headband has rotating joints that will fit to the shape of your head, too. There are four built-in microphones so that some of the mics can be used to cancel out background noises and keep your voice crystal clear when you use the headphones to communicate.
