The Anker Zolo Liberty true wireless earbuds have dropped to $60 on Amazon
True wireless earbuds have sort of taken the headphone market by storm, haven't they? There are so many options, and if you're interested in them you'll need to decide for yourself the ones you want. All I can do is provide you with a way to save on a great pair right now. The Anker Zolo Liberty true wireless earbuds are down to $59.99 with the code ZL2001HP at Amazon. That price is $10 better than a deal we shared in September and one of the lowest prices we've ever seen. The earbuds sell for $100 without the code and regularly go for that price since Anker updated them.
Anker Zolo Liberty upgraded true wireless earbuds
These Bluetooth earbuds have precision oscillation for superior sound. Each earbud has eight hours of playtime with an extra 100 hours using the charging case. They are IPX5 rated for sweat resistance so you can visit the gym.
The Zolo Liberty have been recently upgraded to feature even better features than they did before. The earbuds now last up to eight hours on a single charge, and you can bump that up to 100 hours using the included charging case. That's a long time before you ever have to plug these into a wall to recharge. That means you can take these just about anywhere and listen to music while you're working or traveling or sweating it out at the gym.
They use graphene-coated drivers with precise oscillation and superior sound. Plus, the improved Bluetooth 5.0 tech means a much more latency-free experience. Your music won't get disrupted and will continue to sound great even without a wired connection.
The earbuds are IPX5 rated, too, which actually means they can be blasted by water jets without anything bad happening. But they also include water resistance to sweat so you can take them with you on your next workout.
Need some more options to consider for true wireless earbuds? Check out our roundup, which does feature the Anker Liberty Air earbuds as the Best Value. In this moment, though, the Zolo Liberty have them beat because they aren't quite as robust as the Zolo Liberty and aren't quite as inexpensive thanks to today's deal.
