Anker's PowerPort wall charger on sale for $18 includes a USB-C port with Power Delivery
We all have a bunch of devices to keep charged these days (and you may have added to your gadget collection today) with some devices needing USB power and others moving to USB-C. It can be hard to keep everything topped up and remember to bring the right wall charger with you when you travel, so it's wise to pick up a charger that can power up whichever device you need. The Anker PowerPort Speed+ Duo is one such charger, and right now you can snag it for just $18.19 at Amazon. All you have to do is clip the coupon on its product page there to score 30% off. This is the first time we have seen this charger drop this low ut that coupon could expire at a moment's notice.
Anker PowerPort Speed+ duo USB-C 30W Power Delivery wall charger
The PowerPort Speed+ has one 12W USB-A charging port for pretty much all your mobile devices as well as a 30W USB-C PD port that's powerful enough to charge devices like laptops, tablets, or the Nintendo Switch. Clip the on-page coupon to save.
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The PowerPort Speed+ Duo has two ports as the name suggests. One is a 12W USB-A charging port for pretty much all your mobile devices. The other is a 30W Power Delivery USB-C port that's powerful enough to charge even advanced machines like laptops, tablets and more. The whole thing is compact and it has a foldable plug so you can keep it with you no matter where you go. It also has plenty of built-in safeguards to keep your things safe.
Existing owners rate it highly with an average rating od 4.3 stars out of 5 based on over 260 Amazon reviews. Anker backs it up with an 18-month warranty, too.
Now your home charging needs are covered, why not check out our list of the best USB-C battery packs for some on-the-go power and snag some USB-C cables while you're at it?
Adam Oram
