Use the code N326FEYW during checkout and clip the 20% off on-page coupon to get the Aukey USB-C 60W fast charger with foldable plug down to a $14.29 total. The stacked discounts bring it down to a crazy low price compared to the $26 it normally sells for. The charger was selling as high as $30 in July and has never gone lower than today's $26 price directly, so the deal is a unique one and will save you a bunch of money on a charger you're sure to find good use for. Aukey even has a similar 2-port charger that ends up only being a couple bucks cheaper than this one despite being half the power.
Get juiced
This is a single port charger, but that port is USB-C so it can charge your stuff ridiculously fast. Has enough power for laptops like a MacBook or Dell XPS, too. Use it with your new iPhone 12 or a Nintendo Switch. Keeps electronics safe.
$14.29 $26.00 $12 off
The 60W charger is powerful enough to work with most Power Delivery compatible devices. That means it's great for laptops like the MacBook Pro or Dell XPS, but it also works with mobile devices like the new iPhone 12 or any USB-C powered Android smartphone. You can even use it with the Nintendo Switch. You can get a modern smartphone up to 50% in just half an hour with this charger thanks to the advanced GaN power chip that improves charging efficiency. It also helps cool the internal components so there's no overheating or loss of efficiency that way.
Thanks to the power chip, the whole charger actually ends up being much smaller and more compact than similar chargers. Even the chargers that come with your devices will look like bulky messes compared to this. Take the Aukey charger with you whereever you go thanks to the foldable plug that makes it easy to travel with.
The built-in safeguards protect your charger and any connected devices. You won't have to worry about things like overheating, overcharging, short circuiting, or excessive current.
Check out iMore's favorite gadgets and accessories from CES 2021
Another CES has come and gone, and now it's time to name our favorite products from the show. Here are iMore's favorite accessories that we saw come out of CES 2021.
Apple reportedly has new iMacs, a new display, and new Mac Pros coming
Apple is said to be working on all kinds of things, including something akin to the G4 Cube!
Get more out of your aircraft with these must-have drone accessories
You'll get more out of your drone with a few accessories. Whether you're looking for a landing pad, bag for your aircraft, or tools, we have the rundown on this year's best drone accessories.
