Aukey's USB-C wall charger with Power Delivery is 50% off on Amazon
If you clip the on-page coupon you can save 50% on the Aukey USB-C 27W Power Delivery wall charger. That coupon brings the total down to $12.99 from its regular price of $26. Without coupons like this, the wall charger has never dropped below its regular $26 price.
You can also go with the black version at the same price using a similar coupon code. Both devices say they will arrive before Christmas, too, in case that's important to you.
The Power Delivery has 27W of power. It can charge your mobile device, a Nintendo Switch, a MacBook or other laptop, and anything else that supports USB-C charging. Foldable plug makes it portable. Built-in protections make it safe to use.
With 27W of power, the Aukey wall charger has more than just speed and efficiency. It has enough output to charge devices larger than just your iPhone 11 or Galaxy S10. You can use this USB-C charger with the Nintendo Switch, a MacBook or Chromebook or other laptop, and anything else that supports USB-C Power Delivery. Use this adapter if your old one is broken or just not as powerful. You could actually find a small improvement like this makes using your devices a lot nicer.
The charger is designed for portability and convenience, too. It's slim and lightweight and just one-inch thick. The plug is foldable so the whole thing becomes compact and fits easily in your pack without getting snagged on anything. Use it in the office, at home, or while traveling.
Aukey always has built-in safeguards that help protect the charger and whatever is plugged into it. Don't worry about things like excessive current, overheating, over-charging, or any sort of issues like that. The adapter is not going to let bad things happen to you!
Aukey backs up all its devices with a two-year warranty, and users give it 4.5 stars out of 5 based on 18 reviews.
Grab a USB-C to Lightning or USB-C to USB-C cable based on the device you plan to charge with this adapter.
John Levite
