Best Battery Cases for iPhone 7 Plus in 2022
Despite the size of your iPhone 7 Plus' battery, you may find it's not lasting through the day, especially if you're a power user. Carrying around an external battery pack can be cumbersome, so why not streamline the process and grab a battery case instead. It'll probably bulk things up a bit, but better bulky than a brick.
Which should you buy?
All of these battery cases will be compatible with both the iPhone 7 Plus and the iPhone 8 Plus. For my money, the Smtqa battery case is the best option, since it has 80,00mAh battery power. It should keep your iPhone going at least all day and into the next, and it's protective without being extremely bulky.
Latest Videos FromiMore
If you're wary of buying an unknown brand, the Mophie Juice Pack carries a well-known name, so it's a brand you can trust. Plus it comes in a variety of fun colours and is guaranteed to keep your iPhone's battery secure.
Karen S Freeman
Contributor
