Bring along some power with Anker's PowerCore 13000 portable charger at over 40% off
Convenience comes at a price, though it just became a little bit more affordable. Anker's PowerCore 13000mAh Compact Power Bank can help make sure you always have a way to power up your smartphone, tablet, and other USB-powered devices while you're traveling or away from a permanent power source. Now, thanks to a sale at Amazon, this portable power bank is on sale for as low as $21.24. That's one of its best prices in years, though only the Black model is priced this low currently. You can pick up the Blue, Red, and White versions for $27.99 each, which is still a nice $10 discount off the full price of $38.
Anker PowerCore 13000 Portable Charger
Bring enough power to recharge your smartphone several times using Anker's compact PowerCore 13000 power bank. It features two USB ports and even comes with an 18-month warranty. Red, Blue, and White models are on sale for a few dollars more.
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This 13000mAh portable power bank is equipped with two high-speed USB ports to charge your devices with, along with a micro-USB port designed to charge the battery itself. That allows you to power up two devices at the same time with PowerIQ and VoltageBoost technologies offering an optimized charge per device. At up to 3A per port, you'll generally receive a fast charge no matter what device is currently plugged in. The power bank is pretty compact and slim too, thinner than some wallets even, making it possible to just slip it into your pocket.
No AC adapter is included with this power bank's purchase, so you might want to add one to your order if you're in need. Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you're not a member already, why not consider starting a free 30-day trial? You'd score free two-day shipping, exclusive members-only discounts, access to the Prime Video streaming service, and more.
Not sure if the Powercore 13000 is the right power bank for you? Android Central's guide to the best power banks under $30 has several other worthwhile options right around today's sale price. You could also take a look at this list of the best portable high-capacity power banks if you want one that has enough juice to power up your laptop and other devices.
