This discounted charging station can power up to 10 devices at once for $27
Trying to charge all your devices at once can be pretty maddening if you're missing the right accessories. Luckily, the Unitek 10-port Multi-device Charging Station can make things much easier while keeping your workspace organized in the meantime. Today it drops to just $26.99 at Amazon when you use promo code 5EW46PPM during checkout. That saves you $15 off its usual price and brings it lower than it's reached in a few years.
Charge more devices with this 10-port USB Charging Station which comes with 11 detachable dividers so you can adjust the spacing for whatever you're planning on charging. It powers devices at an optimized charge based on what's plugged in.
Unitek 10-Port USB Charging Station with QC Qualcomm Quick Charge for Multiple Devices, Smartphones, Tablets, Universal Charging Docking Stand Supports 5 iPads Charging Simultaneously - [UL Certified]
$29.29 $41.99 Save $13
Unitek Portable Bluetooth Speaker
$8.95 $13.99 Save $5
Connect wirelessly to this portable speaker via Bluetooth from up to 30 feet away.
With ten fast 2.4A charging ports, this charging station is capable of powering up to ten devices simultaneously with a max 12A output. You could plug in your smartphone, tablet, Bluetooth speaker, and practically anything else that's USB-powered. The charging station features Unitek's multi-protection safety system for complete protection against over-charging, over-heating, over-voltage, and short-circuiting. It includes built-in surge protection as well, and there's even a vivid LED display to show its charging status.
There are 11 detachable dividers that come with this charging station too. They let you adjust the width of the spacing between them so you can fit larger devices and fit pretty much any device whether it's in a case or not. Unitek's charging station even features Smart IC technology which provides an optimized charge per device and stops charging once the battery is full.
This charging station will do a great job at making your workspace look more organized, but it'd be even better with short charging cables rather than long ones that would get all tangled up. If you don't own short USB cables already, you can pick some up at Amazon affordably.
Shipping at Amazon is free on orders totaling $25 or more, but you could receive your order even faster with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, along with access to perks like the Prime Video streaming service, exclusive members-only discounts, and more.
