Keep everything plugged in at once with UGREEN's discounted 6-in-1 USB-C Hub
Ever feel frustrated with the lack of ports on computers these days? If so, it sounds like you're in need of a USB-C hub. The recently-released UGREEN 6-in-1 USB-C Hub just went on sale at Amazon thanks to a clippable coupon on its product page as well as code UGDEC410 taking it down to just $15.74. It has been selling for $21 recently and has never dropped far below $20 before without a special code like today's deal. Even with coupons, we've never seen it go this low in the past.
Now at a new low price, this USB-C Hub can help you connect printers, hard drives, 4K monitors, SD cards, and more to your computer, though you'll need to enter the below code to score the lowest price.
This USB-C hub is packed with three USB 3.0 ports that support data transfer speeds up to 5Gbps, along with a 4K-compatible HDMI port as well as SD and TF card readers. Best of all, they can all be used simultaneously if need be, whether you're plugging in hard drives, flash drives, a USB receiver for a wireless keyboard and mouse, a printer, or another device. Meanwhile, its sleek aluminum finish helps it look right at home next to computers like the Apple MacBook.
If this UGREEN option doesn't have quite the right I/O options for you, be sure to check out our lists of the best USB-C hubs for Chromebook and the best USB-C hubs for MacBook devices for some alternatives.
Adam Oram
