Skip to main content
Keep your tech charged with up to $20 off Aukey's high-capacity portable battery packs
We carry a bunch of tech with us each day, and all of our devices need charging so it is a great idea to carry a power bank. If you're going to be away from an outlet for a long period of time, it makes even more sense to take a high-capacity battery with you so you don't have to worry, and Aukey is offering two such power banks at a significant discount for a limited time.
The first is the Aukey 30000mAh USB-C Power Bank (opens in new tab). It's a fully-featured device that usually sells for $76.99 but currently has a $20 coupon on its product page taking the price down to a new low of $56.99, though that coupon could disappear at a moment's notice.
(opens in new tab)
You can power up your devices quickly with this 30000mAh power bank, and get them to 100% multiple times over before you need to recharge it. It has two USB-A outputs as well as a USB-C PD port. Clip the on-page coupon to drop the price.
As the product name suggests, this battery has a huge capacity. At 30000mAh, it can charge an iPhone 8 over 11 times, and even has enough juice to charge up tablets and laptops a couple of times over. It has two USB-A outputs, one of which is Quick Charge 3.0-enabled, as well as a USB-C output that offers 30W Power Delivery. That means it is perfect for powering up larger devices like the Nintendo Switch or your MacBook. That USB-C port is also used for speedily recharging the power bank itself, and there's a micro-USB input that can be used at the same time for an even faster refill.
A USB-C cable is included with your purchase, as is a 24-month warranty.
(opens in new tab)
Aukey 30000mAh USB Power Bank (opens in new tab)
If you're going to be away from an outlet for a while, you ought to bring along this high-capacity dual-USB power bank. When full, it can power phones up to 10 times over and larger items like tablets twice. Use the on-page coupon to save.
Aukey 9-in-2 USB-C hub for MacBook Pro or MacBook Air
(opens in new tab)
$41.99 $60.00 Save $18
Unique design requires two USB-C ports back-to-back, which is why this is particularly suited for a MacBook that has such a configuration. Turn those two ports into nine tools including HDMI, Thunderbolt 3, and a 100W Power Delivery charging port.
Aukey Sports true wireless earbuds with earhooks
(opens in new tab)
$27.49 $50.00 Save $23
Include powerful 12mm drivers for high-fidelity audio. The ear hook design won't let go even when you're at the gym. They have IPX8 water resistance, which is full waterproof support. The battery life lasts up to 35 hours with the included case.
Aukey Bluetooth true wireless earbuds
(opens in new tab)
Up to 30% off
All the prices are discounted and the costs vary between $21 and $49. All you have to decide is which one looks best to you and has the features you need (like the Sports earbuds that stay on even while you run). Choose from black, white, and pink.
Aukey KM-G6 LED Mechanical Gaming Keyboard
(opens in new tab)
$27.99 $44.99 Save $17
This well-reviewed keyboard features 104 anti-ghosting keys, nine preset lighting effects, and even comes with a two-year warranty. Today's deal at Amazon saves you $12 off its regular price while supplies last!
(opens in new tab)
$25.24 $50.00 Save $25
If you're not yet all-in on USB-C, you could opt for Aukey's Dual-USB 30000mAh Power Bank (opens in new tab) instead and spend even less. It usually goes for $44.99 but an $8 on-page coupon drops its price down to only $36.99. That's within a couple of dollars of its best price ever and the lowest we've seen in over a year.
It has the same high capacity with two USB-A ports with a combined 4.8A output. It also has an LED flashlight, so is a great option for taking on camping trips. It makes use of micro-USB and Lightning for its inputs so you can likely use the cables you have lying around to get it back to full, too.
