Charge with RAVPower's 16750mAh Power Bank anywhere at almost 60% off
Leaving home while your phone's battery is almost dead doesn't have to be a crisis. With RAVPower's 16750mAh Portable Power Bank (opens in new tab), you can charge it back up on the go and have plenty of juice left over to recharge other devices too. Though it's normally sold for $36, Amazon is offering nearly 60% off its regular price when you clip the coupon on its product page and then enter promo code 50W5C77D during checkout.
RAVPower 16750mAh Portable Power Bank (opens in new tab)
This pocket-sized portable power bank is equipped with two USB ports and a 16750mAh battery capacity that can recharge your phone a few times before running out of juice.
RAVPower 65W 4-port USB Desktop Charging Station
$34.99 $49.99 Save $15
Keep USB ports close by with this 65W USB Desktop Charging Station by RAVPower. It's equipped with two USB-C ports as well as two USB-A ports. Clip the coupon on its product page and use the following code at checkout to save $15.
RAVPower 10000mAh portable charger dual USB power bank
$9.99 $15.00 Save $5
The ultra slim power bank is only 15mm deep, so it's extremely portable. The battery size of 10000mAh is enough for a full charge of even the largest phones. Can charge two devices at once and has built-in safety features to protect them all.
RAVPower 61W Power Delivery 3.0 USB-C 2-port wall charger
$23.39 $30.00 Save $7
Has 61W output with Power Delivery 3.0. Can charge a MacBook in 2.1 hours. Can detect what's plugged in and deliver fastest possible speeds. Wants to be portable with slim, compact design and foldable pins. Includes built-in safeguards.
RAVPower 48W USB-C Car Charger with Power Delivery 3.0 and Quick Charge 3.0
$14.99 $19.99 Save $5
RAVPower's fast dual-port car charger features a 30W Power Delivery 3.0 USB-C port along with an 18W Quick Charge 3.0 USB-A port. Clip its on-page coupon to snag this deal.
RAVPower 25000mAh solar phone charger outdoor portable charger
$21.99 $46.00 Save $24
Use sunlight to recharge this charger's batteries or plug it in via micro USB or USB-C. The 25000mAh capacity is enough to keep all your devices going outdoors. Includes an LED flashlight and SOS mode for emergencies. Waterproof and dust proof.
This power bank was designed to be much smaller and lighter than previous RAVPower portable chargers, and with its 16750mAh battery capacity, it's capable of recharging the iPhone 8 more than five times before needing to be charged up again. Its 2A input offers a quick way to refuel while its two USB ports provide 4.5A of power in total. There's also a battery indicator LED light so you never have to wonder about its charge, while advanced safety features protect against overcharging and short-circuit.
You'll need a way to power up this portable charger, and while a USB wall charger (opens in new tab) is fine for at home, adding a car charger (opens in new tab) to your order will let you power it up while you're on the road too.
iMore Newsletter
